Remote power input in Hifonics amp
the remote input on the amp connects to the remote wire on the HU so the amp turns on when the HU is on, you could wire it directly from the battery with a switch but thats generally not suggested, from the HU is the way to go
Like they said, Your head unit should have a Remote Turn on wire, extend it back to the amp and connect it there...
Think of it as a trigger wire...
When you turn your HU on it'll trigger your amp to turn on, when you turn off the HU, it'll again trigger it, but off....
Its sorta like a reay inside the amp, but can draw a tad more current...
You can connect the amplifier remote turn on to the red 12v accessory wire that turns on the stereo when you turn on the key. The amplifier will...
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
986
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
DbRufus1234
DbRufus1234
Northport, Alabama
smullen
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
