Recommended amp for Rockford r2d2-12
  • 2
jordyvl
Hey very new to this scene just want a bit of advice for what I should use to power my Rockford R2D2-12. I've found a cheap fusion CA-DA411400, would this be a suitable fit? Thanks in advance for any words of advice.
Specs for amp:
  • Peak Power (Watts): 1400
  • Rated Power (Watts): 150 Watts RMS x 4 @ 4 Ohm 1% THD+N 220 Watts RMS x 4 @ 2 Ohm 1% THD+N 440 Watts RMS x 2 @ 4 Ohm Bridged 1% THD+N
Specs for sub:
  • Peak Power: 500 Watts
  • RMS Power: 250 Watts
  • Nominal Impedance: Dual 2-Ohm
It's not a great match, primarily because the amp is a 4 channel. You can't combine all 4 channels to power the sub.
However, you COULD bridge two channels to run the sub leaving the other two available to run a pair of full range speakers.
It is a completley new truck except for what is painted red. It has a TCI custom chassis, four wheel disc, four corner adjustable coil overs ...
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
You need to accurately and carefully measure your trunk out, and decide how much space you want to use, too. Always measure your trunk out before...
This is correct. Those insurance /extended warranty people dont want to pay for anything that isnt listed on the contract, of which to most is...
151
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
213
jordyvl
jordyvl
Australia
jordyvl
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
