2 psi plat 2 on stock 110amp alt which amp should I buy? Budget at 500. If I need to go a bit more which one should I get? Both subs will be at 2ohm so final load at 2 ohms.
Sent from my SM-G935T using Tapatalk
I see these are 1,500W RMS at the standard performance level. With a pair and a 110 amp alt that means you're going to have to underpower them by quite a lot.
i own 1. i was planning on buying another and i dont think the cab can power 2? or if it did it would share 1255 so maybe 600 a woof? idk what would be better? 1 going 1600 or 2 going 600 each? you going to recommended me a zapco arent you
I wouldn't get the CAB amp, as you'd only use 1/2 the amps power. Kinda a waste to me instead of using the amps full power @ 1 ohm, and if you had D2 subs.
right now the cab is doing me justice at 1 ohm with my 2 ohm sub but i want more. specifically another sub but need an amp to power 2 unless i get anothher cab to each sub?
