Realistic RMS on this amp?
audiopipe amps are great. i sell a lot of them. and the mini are really awesome for their price. I use them a lot, particulary the apsm1300, its a beast for its size honestly.
thanks for the replies guysI'm mainly looking at these two amps now, both for $100
Cadence F700-1 1600 Watt Class AB Mono Block Amplifier | eBay
AUDIOPIPE APSM-1300 2000W MONO Car Audio MINI Amplifier | eBay
I researched them a little bit and didn't really find anything bad about either brand, but was wondering what you guys thought about these two? Would the cadence amp be able to do the 800 watts RMS it says it can?
thanks
either will do just fine, the cadence will give clean rated power and the ap should do very close to rated clean, if not a bit over
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
818
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
849
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
tf3090
tf3090
SD
BlactimusCrime
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
