RE8s, one moving more than the other
tomd
Montana
Hey guys, i've had my RE8s in my car for a while (ported), but i just put a new amp in (Hifonics NX400), and i cranked it and was looking at 'em, and one of them is moving a lot more than the other, the thing that confuses me is that they are wired in series, so i don't see how it could be a loose connection or something....
Why would they do this? Could it just be a bad sub or something? Due to improper break in or something? I got them at the same time, bought new, never installed otherwise....
Also, what happens when a sub bottoms out? Does it make a hell of a racket?
amp is bridged, then the subs are in series, sooo
+ of amp goes to + of first sub, - of first sub goes to + of second sub, - of second sub goes to - of amp
It's because they are in series. The speakers will interact with each other electrically when they are wired in series. If at all possible you want to wire each speaker in parallel. What you do with each voicecoil doesn't affect anything other than the final load seen by the amp. I assume you want a 4ohm mono load. Wire the coils of each sub in series (connect the + of one coil to the - of the other) then wire the two subs in parallel (available + of each speaker to the amp + and the same for the available -). That will give you the same final load without any speaker interaction.
single 2 ohm voice coils IIRC
EDIT: should i add another terminal cup to the back ( i have another, but i gave my boss his holesaw back =/ ) and since the amp is two channel, just wire one to each?
Could this be the reason why when I had my 2 HC's wired to 1 ohm each, then wired them to 2 ohms that they sounded like crap, but when I had 1 at 1 ohm it sounded amazing??
Based on everything else you've said so far, I'm wondering exactly how you have the LoC connected "through your subwoofers". Is it possible that...
23
4K
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
891
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
994
tomd
tomd
Montana
Dupuis
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
