IMOVeCHICKENS! 10+ year member
Firtyfwe here ngz
xxxxxxxxxxxxxxxxxxxx2The new XXX is at it's best in large sealed enclosures...
this is what you need
Good post. I'd like to have a XXX as a HT sub.The new xxx is not garbage. Its not at the top of my list of subs Id prefer, but in the right enclosure its very capable. In the right sized sealed enclosure (large), no other sub can touch this driver. But this forum is heavily biased towards vented enclosures, so its seen as garbage.
They require large enclosures because to get anywhere near its excursion potential, you either need a lot of power, or a large enclosure. The xxx's coil cant withstand 5kw for daily use, so the big enclosure is the only realistic option. But on this forum, most people would rather just go with a more traditional driver in a ported box, rather than the xxx in its over sized sealed box.
i have noticed that. very true.The new xxx is not garbage. Its not at the top of my list of subs Id prefer, but in the right enclosure its very capable. In the right sized sealed enclosure (large), no other sub can touch this driver. But this forum is heavily biased towards vented enclosures, so its seen as garbage.
If the XXX is so much better in such a large enclosure, then why doesn't RE recommend that in the first place? Their recommended ported box is 4.0 @ 33hz. If it sounds so bad in the box that they recommend, then why are they recommending it in the first place? I'm not trying to argue, just trying to figure this out. I have an XXX 15" ('09 model) in a 5.0ft. (after port & sub) @ 33hz box. Sounds OK to me but I may just seal the thing. I'm finding it somewhat peaky sounding if my xover is set higher than 50hz.either large sealed or larger ported tuned low is the way to go with the XXX...a conventional box used for traditionally(and commonly) lower-Q woofers does not work with them, whatsoever.
