radio dosent pick up stations clearly, whats go on?
Check beind your deck to make sure the antenna plug hasnt come loose, or is rattling around back there....You should be picking up radio fine, depending on the area you're in.
I have the same problem,after I hooked up all the equipment is when I started getting all the static crap and thats the local staion,the staions in the city I dont even pick up.Gonna try a FM booster see what happens.I also read somewhere that certain amps might cause the interference.
DbRufus1234
DbRufus1234
Northport, Alabama
strong*I*bumpin
JayBoogie808
    Apr 17, 2025
JayBoogie808
    Apr 17, 2025
