Question!
its wired wrong you blew out your front door and back speakers. Take out the headunit check all the connections. IF not working after that call an audio shop let them take a look. sounds like a connection problem with the install. Worst case u can try to replace the speakers but not a necessity.
As stated- most likely improper connections.
Since this is in a Sable- it could have a factory amp that would need to be bypassed.
Are you using the HU to power the mids/highs?
take it easy,
-zane
well there you go. You need ot hook up the subs to the headunit check the settings also make sure u have the wires from the subs connected to the amp.
Audiomaster
Audiomaster
Texas
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
