Question about HifonicsBX1500D settings (SSF, Eq, Low Pass, etc..)
Vicious
24
ky
Hey, I just got finished with my VERY FIRST INSTALL and I have some questions about what my settings should be on my Hifonics1500D amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What Ive got is a 15" Magnum D2 sitting in a 3.2ft^3 box ported at 32Hz, running stock alt. and battery (yellow top should be coming in soon, alt will get ordered in about a month or so). Im using an Alpine H-U.
If anyone could give me some help on the following options that would be awesome:
SSF (15-35Hz)
Bass Eq.(0-18db)
Low Pass (20-250Hz)
Phase (0-180)
Level (.2-9V)
What would you recommend these be set to? I have no idea how to determine these things v_v
The sub is wired at 1-Ohm....also, where should I set my bass control knob? All the way down? Right now, the sub is almost barely audible when the bass control is set on 0, but maybe my other settings are causing this?
Thank you! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
SSF - Around 25
Bass EQ - I don't use mine, but I wouldn't go higher than 6dB's.
Low pass - Depends on where you have the high-pass for your interior speakers...generally speaking, it should be around 70-110 or so...play around with it.
Phase - Just keep it at 0 for now. You can play around with it after you get everything else set up correctly.
Level - This is probably the cause of your sub not being all that audible...you want this to match the preout voltage of your HU. Do a search, there's a thread about properly setting the gain...I don't feel like explaining it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
254
https://www.amazon.com/dp/B0CJB5TTPB/?tag=caraudiocom-20
8
684
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
734
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
999
Vicious
Vicious
ky
Gauntlet
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
