Question about Cross Over
Riven
I bought a head unit with a cirss ovetr i can set at 80 or 120 and a jl 500/1 amp that also has built in cross over do i still need to buy a seprate cross over? if so what brand? or is there something else that will up my subs proformance? right now i have nothing but head unit amp to sub
riven-- how many preouts does your headunit
have (meaning front,rear, and sub. and is the
built in crossover a high pass and low pass.
and the crossover that is built into the jl500
is it a low pass and what feq can it be set to
(meaning 50,80,or 120
I am assuming the head unit's crossover is on a sub pre-out. The JL 500/1 has a variable 40-200hz crossover that can be set to 12 or 24 dB/octave.
You'll have all the crossover slope you'll need using the HU's and amp's crossovers in conjunction.
Depending on your listening preferences and other mid to low bass drivers in your system you may only want to use the HU's x-over or the HU x-over and amp x-over set to 12 dB/oct.
Test your different combination options to suit your listening needs.
But at any rate, another x-over would be a waste of money and installation time.
Riven
Riven
Saint jo
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
