question about alternators from Bronco Graveyard site
Ridinhi
I have a 1996 F150 with the stock 95 amp alternator. I have power windows and with just putting my windows up/down, my voltage drops. Ive come across these high output alternators on Bronco Graveyard site and would like to know if it will be a good buy or not. Not sure who makes them. Im looking at either the 170 or 200 amp alternator. I am running a 400 watt 2 channel and a 600 watt mono amp. I did the big 3 but I used cca wire, 0 gauge. I just ordered some ofc 0 gauge and will be getting a Diehard agm from advance auto. My current battery is a walmart value battery, group 65( the $50 battery).
Opinions appreciated
Off brand HO alternator will probably be an upgrade over stock and do what you need. I certainly wouldn't suggest shelling out 500$ and up for a premium one for a 25 year old truck and a small stereo system. Honestly I'd just do a higher quality AGM battery up front and see if that doesn't do enough on its own first.
I've ordered from Bronco grave yard before. Good company. Butttt You can get a 130 amp 3G alternator out the junkyard for $40. They are pretty bullet proof alternators.
95a is the small case and 130 is the large case. Bolts right in and plug and play.
I've had a couple OBS F150s.
4 holes = 95amp and 2 holes = 130 amp
If I find one that’s 130 amp, will I still be able to use my same belt? I’m asking because the pulley looks a tad smaller in the 130 amp unless it’s just the pic
That’s exactly what I plan on doing. AGM plus I’ll try a 130 amp alternator if I find one a pull a part this weekend. Thanks for the info guys!
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
591
That would be fantastic! Id love to see the skills involved here. It always intrigues me to see some customizing from small and detailed to large...
382
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
Ridinhi
Ridinhi
Winston-Salem, NC
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
