Quad Voice Coil question???
kickerlivinloud
Banning survivor
Is there any advantage to this other than you can have more wiring configurations?? I am asking b/c the DP I plan on getting have the option for it and I see that most of the comp installs that have them all seem to have quad voice coils. Is it that I am not seeing a lot of installs or is there a advantage in comps for 4 vc unstead of the normal dual???
Your imput is appreaceated...
Jon
K, another question, Do you think the DP can handle a Orion 2500D???? I would run it at 4 ohms = 1200w RMS for my daily set up and 1 ohm = 2500w RMS for just comps. Do any of you think she can handle it, I would like someone with personaly experience with the DP if at all possible if not I am open to everyone elses opinion.
Jon
Most installs with Quads allow for higher power use and in some cases(not all) comes out cheaper.
If you're running normal power, don't bother with quads.
Ex.
Option 1
1-15" Quad 2-ohm Coil Audiobahn Immortals
8 Visonik V900XDs
Each coil gets 3000+ watts from strapped 900XDs.....12000+wtts rms
Option 2
1-15" Dual 2-ohm Coil Audiobahn Immortals
4 Visonik V900XDs
Each coil gets 3000+ watts from strapped 900XDs.......6000+ wtts rms
Yeah that makes since b/c one of the installs i read about was from IA and it had 1500 RMS to each coil with a grand total of 30,000 RMS with 5 DP quads. My one question still stands does anyone think the DP can handle 2500w (only in comps)????
Hey thanks Fam, I appreceate it alot. I am really looking forward to getting all my stuff in and get it all hooked up and then go to a couple of comps. I will let you all know how the DP does when I get everything hooked up...
Thanks agian...
Jon
quick question on the Orion 2500D, does it have a ssf??? I have been looking at it and can't seem to find if it does or not. If not I know this has been asked b/4 but were could one find a ssf and how $?
I would think it would come with one. If not you can get a PG bass cube or a crossover that has one. Harrison Labs makes inline subsonic filters in all kinds of different frequencies for like 25 bucks, i went with a bass cube for my Mmats amps b/c they didnt have ssf's either. Having a variable ssf is a plus as well...
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
Those are the same kinds of programs they have on the cellphone tech lines. You talk to the cellphone and they direct you to options from the...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
793
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
kickerlivinloud
Banning survivor
kickerlivinloud
Finger Lakes, NY
InhumanAcura
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
