Pyle PLA485 / Morel Tempo Ultra 602
cas0586
WV
Dug up an old Pyle PLA485 2CH Amplifier I was given some time ago. Also recently purchased a Morel Tempo Ultra 602 component set for front stage. Component set is rated for 120WRMS. The amplifier is claiming 130W. The manual does not state RMS, but many places online are stating that it is RMS. Any thoughts on this? Will this amplifier not do these speakers any justice? I am tempted to get a 4CH amplifier and go active, but I have no experience with that.
If active is the answer any suggestions on a [<$200] 4CH amplifier to drive the Morels midbass and tweeters separately?
This little thing probably doesn’t even make 200 watts. I would towards a Korean made 4 channel around $200
and the thd rating on sonic electronics is 1.04% not 0.04% hmmm
You can do so much better than that Pyle amp.  I'd say get the Pioneer GM-D9605 5-channel amp.  This way you have the amp to push a sub when you decide to get one.  And, it's only $208 on Amazon.  Much better power for your Tempo Ultras than the Pyle, also.
You can get the Pioneer GM-D8604 for around $130. 4 channel that puts out over 100rms per channel (proven on dyno). I would'nt run the Pyle unless you really had no choice. It's just not a good product.
I picked up a US Acoustics Barbara Ann to drive these. The Pyle was only something laying around that was given to me. It was used on an MTX Thunder 4000 10" on power wheel trailer then went unused.
Well that sounds better. A US Acoustics Barbara Ann. Now your getting some place. A suggestion, you can use that Pyle for a door stop, or just better yet take it to that next electronic waste recycle collection round up most cities have every few months. 😀
the name Pyle used to mean something good, now its quite a bit more literal. Why arent people recommending the Zapcos more? Good amps, good power and i havent seen anywhere where people have reported them releasing their magic smoke. You can cook an egg on them when running them hard at 2 ohms, but thats how theyre designed to run
Nice thing about the Morels is they don't require a lot EQ. Since the midbass will likely be far from the mid & tweeter, you could benefit from...
976
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
cas0586
cas0586
WV
youdoofus
Random4thGuy
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
