preouts
  • Thread starter Unregistered
  • Live activity
  • Replies 8
  • Views 964
U
Unregistered
Guest
hey um, i have a tahoe, and i need to get some preouts to the back, but have stock cd player. can't I clip wires to back speaker and clip some rca's and put em all back together and get my preouts out of the speaker wire? I think i've seen it done, but these ppl were by no means professionals! If not, what do I need to get to some preouts to the back where my amp is?
There are "line level converters" made just for that purpose. Basically they're just a resistor network that drops the high voltage levels from the speakers down to something the RCA inputs on an amp will handle.
You should've bought an amp that has that feature built in. Most do.
okay, when you said, you should have bought an amp that has that feature... what feature?? one that i could clip speaker wires and wire in rca's and the amp will convert it to something the amp could handle, or is the line converter necessary?
I think what he meant was that some amplifiers come with "high level inputs". This means you would not need the line out converter to reduce the current from the speaker wires. RCA inputs on amps can not handle the voltage coming from your factory deck therefore you need a LOC to achieve the proper voltage to run into your amp. hope this helps
Originally posted by Unregistered okay, when you said, you should have bought an amp that has that feature... what feature?? one that i could clip speaker wires and wire in rca's and the amp will convert it to something the amp could handle, or is the line converter necessary?
no thats not what i ment you fukin dumb *** .
Yes. Sorry I wasn't more specific. Some amps have speaker level inputs, as cfurtick said, that connect directly to the speakers instead of using the RCA jacks.
LOC **** anyways, i used to run a factory hu in my car, but it hurt my sq and spl, till i got rid of it and bought an aftermarket h/u, replacing oem stuff is the best thing you can do.
Guest
taylor
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
