Or rather than risking your hearing and your speakers, you could just disconnect the speaker leads. Voltage is voltage. Potential exists whether there is current or not. V=IR. For a constant voltage as R goes to infinity (open circuit), I goes to zero. Voltage remains the same.You could always measure the AC voltage on the amplifier outputs (while wearing hearing protection) ...
2 ohms - 34.7 volts for 600 watts
1 ohm - 24.5 volts for 600 watts
For your JBL BP600.1 ...
Dunno about those models, but the low end Pioneer I have is rated at 2 volts and actually only puts out 0.4 volts with a 0dB CD in the player and volume control set to 45 out of 60.does anyone know how pioneer rates the 8500 or their middle-upper end h/u's voltage at? because i have my jbl 600.1 (which has crappy tuning knobs on it) on my 8500 and id like to find a definitive way to set it so i can get the most out of my system. is there any sine wave tune i can use to find otu where clipping is?
so id just put the positive and negative ends of the multimeter into the + and - of the speaker inputs in the amp? if im way off its because i dont know much about electronics and voltage yet.Or rather than risking your hearing and your speakers, you could just disconnect the speaker leads. Voltage is voltage. Potential exists whether there is current or not. V=IR. For a constant voltage as R goes to infinity (open circuit), I goes to zero. Voltage remains the same.
is that where the h/u clips in gereral with the internal amp, or how you have your settings with low,mid high, etc? i hav mine set on 48 and havent heard any distortion with my cdts yet.Dunno about those models, but the low end Pioneer I have is rated at 2 volts and actually only puts out 0.4 volts with a 0dB CD in the player and volume control set to 45 out of 60.
2 things to say about that:
1) Volume controls are logarithmic and the output voltage increases rapidly toward the top of the setting. Do ~not~ expect to see 3/4 of the rated output voltage at 3/4 volume. It could be way less.
2) I picked 45 as the HU setting because I use the deck's internal amps also, and that's where they just begin to clip (as measured with a 'scope and 4 ohm load). The preouts didn't clip at that level and probably would reach 2 volts at full volume.
Like the Pioneer Premere series is 4V while the lower models were 2V.
it happens to the best of us //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifI feel stupid ... But thank you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
