Powering the SoloX
What about the Zapco C2K4KW
With two 9.0XD boards in a single chassis, the 4KW is the baddest of the bad boys. The 4KW will pound out over 1,000 watts from each of the four channels into 2 ohms or 1 ohm. Bridged to dual mono use, it will do roughly 5,000 watts, and do it in a package so small you won't believe it!
4 Channel, 4 ohms: 4x300 Watts
4 Channel, 2 ohms: 4x600 Watts
Bridged Stereo, 4 ohms: 2x2200 Watts
Special Order 2 Ohm Version:
Bridged Stereo, 2 ohms:2x2200 Watts
T.H.D + Noise:
Frequency Response: 20Hz - 20kHz; +0 dB/-0.28 dB
S/N Ratio: >85dB
Slew Rate: >20V/uS
Damping Factor: >225
Transient Distortion:
Dimensions: 19.5"L x10.5"W x 7.5"H
you should have an amp custom made for that monster. the sub is insane. who would want such a sub? itll break all windows in your car if indeed you are able to find a amp to power such.
ok ok. but if you insist, ive seen a soundstream amp that pushes 9kw out. forgot the name but you can check it out in the site. but i heard ss still fry eggs over their amps. hehehe.
moreover, if kicker made those subs, im sure they are going to launch an amp for that...or else, its going to be a poor marketing move to sell a sub that big to drive without an amp to go with it.
You could do 2 amps to each coil (provided they can be strapped together). Right now I have 1 D3 on 2 Solo Xs. By May, I will have 2 D3s to each sub. That's roughly around 10 to 12,000 watts to each sub. //content.invisioncic.com/y282845/emoticons/idea.gif.5acb6a39a9b92425414c316dda202bad.gif
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
My experience says that for most people, usually, overpowering subs doesn't really gain much, especially for daily or music. Actual power levels...
5
990
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
When you say power on for a limited time, do you mean power after the vehicle has been shut off or just turning on the radio and it plays for a...
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
colt325e
colt325e
Sactown, California
nice
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
