Port Area Question
No, as a matter of fact, the greater the cross-sectional area of the port, the less chuffing there is at higher excursions, so you get more music and less noise.
EDIT: And I wouldn't say 34Hz is a "low" tuning point, either. It isn't too high, but something like 20-25Hz is low.
i didn't mean that 34 was low, it was just a number to put up, but so basically if you can get 400 square inches of port, it'd be good?
larger port area means you need a longer port
for example in a box thats 4 cubes after displacement tuned to 34 hz with a 10"x10" port it needs to be 49.82" long (winisd)
in that same box with a port thats 40"x10" the port needs to be 210.25" long
so 400 sq inches of port area is pretty impractical, but I suppose you could do it if you wanted to
I've heard you actually start going downhill after the port area gets larger then the cone area, So 400 sq. inches would be a waste
alrighty, that's what i wanted to know
so the port area shouldn't be larger than the cone area of all sub(s) combined?
I think thats right.......BUT I have no proof to back this up!! I've only heard this mentioned a few times.
Maybe rangerman or bigbassman will read this and help out
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
dc audio lvl 3 lvl 4 soft parts recone kit they kot hard af at 27 hz
4
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
Acidburn
Super Mod-like-guy
Acidburn
Tempe, AZ
Acidburn
spokey9
    Jul 17, 2024
1aespinoza
    Jul 15, 2024
