Please respond quickly.
baja_stx
Rookie
I currently have a bid on ebay for two JL 8W3-D4 subs. I thought I was bidding on two 8W3V2-D4 subs.
What's the most you would pay for two new 8W3-D4's? What's the differnce between the two?
If you have any ideas or comments please post. There's less than 24 hrs. on the auction.
I'd say it's not that big of a difference. A JL Audio dealer told me that the difference is minimal between the two woofers, w3 and w3v2.
The most I'd pay is about 80 USD since you can buy RE 8's for 50 bucks each, new from the factory direct with warantee.
You indicate it was installed? Why did the installer not go over the settings with you? They didn't set everything up? What is the system? Did...
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
939
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
816
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
baja_stx
Rookie
baja_stx
Detroit, MI
78nova
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
