trungthiendo
ok, i have 2 4 guage wire running off battery pos terminal and both are fused with 80 amp fuses...which are 120 amps combined
then the 2 power wire a ran back to the trunk of the car to a distrobution block, where it goes to 1 power wire with 30 amp fuse to it, and 1 80 amp to it
the 30 amp fused wire will go to the 4 channel amp, which is a tsunami db4440. Only 2 channel on this will be used so 30 amps is fine, the amp itself has a pair of 30 amp fuses. My guess is 30 amp for front and 30 for rears.
then on the distro block, a power comes off it and fused with 1 80 amp fuse, that which goes to the hifonics amp...if i only have this 80 amp fuse, technically i won't be seeing 1500 watts right???...i am going to be powering a dd 9512 with the hifonics.
any feed back on this wiring schema...? i really want to be able to give the dd 9512 full 1500 watts to have it do its thing...
did i screw myself up an dhave to go get a bigger fuse now???
