How many speakers do you have, 2 or 4, because if it's 2, your fader, from front to back, is just set wrong.
or maybe a Crap Fuse
Check your fuse, it might of half blown so the deck is only getting enough power to turn on the lights(which isn't much)
uhh thats the only thing that comes to my mind, it might also be something stupid like a setting on your stereo got changed, something like, you can make it only put power to the preouts.
you install your self?
cause some wires might have crossed or something, and fried you internal amp in your deck. or some wires got pinched somewhere, did you pull the whole wire and run your fingers along it, because it doesn't always affect the insulator covering of the wire, just the wire inside it's self.
if it's new, send it to the manufacture to get fixed, cause it should have a standard warrenty.
Sorry man i've got nothing. some sounds should be coming out tho. not nothing at all. so it's a connection
Good luck with it
