over rated Bullsh*t
jayroc2k
i have a rockford 551x (75*4). on the "birth certificate" it is said that the amp was tested at 14volts. yet it seems to be general knowlede that rockford amps and other expensive brand names are underrated.
i think they are correctly rated and the cheaper amp are OVERRATED.
take note
i have mine running a 12" sub bridged. it is quite adequate. that means enuf bass for me in the car. not for the whole city to hear!!!1
i don't need tgo whole city to hear, i just wanted to place a thread that deals with all the one million, how many watts do i need??? 2x50 or 1000WATTS!!!!!
Um... all you need to do is take the amount of amps that the fuse(s) can handle and times it by 13.8... //content.invisioncic.com/y282845/emoticons/chicken.gif.218ea7401db50d5e31a7e0b37e05e21e.gif
Well, that would give you an OVERestimate because your calculation assumes 100% efficiency and its drawing max current at all times.
What i like to do is take the amount of fuses x 13.8 x the efficiency rating.
lol
Me, I like to bust out my buddies clamp meter and FLUKE DMM, play my favorite frequency (47hz), then multiply the two RMS readings - boom there's your power at that note just under clipping. No, not peak power, but RMS power as the meters already are multiplying the average output by .707...
So what would you guys the efficiency generally is, 66%? 75%? I don't really know, just curious.
jayroc2k
jayroc2k
london
bergnerk
BP1Fanatic
    Apr 25, 2025
BP1Fanatic
    Apr 25, 2025
