Older pioneer speakers need repair
rmnkys
Hi all,
I currently have 2 of these subs. https://www.pioneerelectronics.com/PUSA/Car/Subwoofers/Champion+Series+PRO/TS-W2000SPL
First, I need to get one repaired. The tinsel lead has come off and needs to be replaced. Does anyone know of somewhere in Arizona that I can take it to get fixed?
After repair, what is the best way to wire these to get the most out of them. (Please send a picture)
Lastly, what apmplifier would you recommend to push these things (depending on how they are wired)
Hi all,
No idea about repair shops in Arizona, but how you wire them completely depends on your amp. You'll probably want to get the best bang for your buck by wiring all 4 coils in parallel
This means you'll need a 1 ohm stable amp capable of delivering at least 1500W @ 1 ohm. Likely a mono class D for efficiency. Which one depends almost entirely on your budget. Cheaper ones I'd recommend getting a Taramp with a variable high pass/low pass filter. Less cheap there's a lot of options that are all decent.
Your options for impedance loads with those 2 subwoofers are 1, 4, or 8. 1 in all parallel, 4 in 2 series 2 parallel, 8 in all series.
Finding an amp that can push 1500W at 8 ohms isn't going to happen, and even 4 will be quite expensive, so I'd stick with amps targeting the 1 ohm value.
Where is the tinsel lead broken? If it is by the terminal or in the middle of the tinsel, anybody that has a soldering iron can fix it ( may have to add a short piece of wire to add length).
If the tinsel has pulled out of the cone side it is probably not fixable without doing a recone.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
166
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
602
rmnkys
rmnkys
Arizona
dragon.breath
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
