ok to overpower alpine?
guru
down wit da king
239
Albany,Ga
Thinking about getting alpine type r componets& coaxials speakers both 5 1/2'' version .Reading thier power handling specs seem pretty low for componets but anyways Im getting a power acoustic a600-4hp amp the specs are 70w x4 @4,85w @2 and 170w x2 bridged rms power. Will my alpines be able to takes this power in stride or should i get another amp? forgot, the speakers metion above will be power on the 1st 2ch the 6''x9''get the last 2 ch power.
i was wondering the same thing, since I was looking at alpine comps as well. Either the 50 or the 60wrms comps. But my amp puts out 75-100wrms x4. Dont want to blow them, so Ill probably go with the CDT CL-61's
Maybe your amp gain is set too high, or wasn't set properly with the head units volume adjusted properly prior to setting the gain since you...
10
So my brother in law came over tonight and was selling gear from his gf’s dad. Alpine PDX M12, M6, F6 and 2 Alpine Type R shallow 10s (older...
Does the radio have two brake inputs? If not, I would first try the e-brake wire. If it does not grant you video access, then try the brake wire...
337
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
869
guru
down wit da king
guru
Albany,Ga
1BadHawk
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
