First, Ford F-150 Fuse #23 (10A) Details:
I currently have a Dashcam wired into a fuse tap to fuse #23 10A in my interior truck fuse box. Can devices #2 and #3 be added to fuse tap (+) by means of two "T-Tap Connectors"?
The following information, I do not know if it is helpful to you in making your recommendation. I thought I would include the info just in case it is needed.
Device Information:
#1: Blackvue DR750S-2CH Dashcam
-DC 12V - 24V (DC Plug (-)--C--(+)
-(03.5 x 01.35), MAX 1A/12V)
#2: ESCORT MAX 360c (Radar Detector): 2A
#3: USB Hub:
Input Voltage: DC 12V-24V
Output Voltage: DC 3.6-6.5V/3A, 6.5V-9V/2A, 9V-12V/1.5A
Portiforium Dimension: 1.13 inches Max Output: 36W(18W each)
- Power driven rear glass switch. [Not Implemented]
- Inverter.
- Driver side window.
- Moonroof. [Not Implemented]
- Vista roof. [Not Implemented]
- Blackvue DR750S-2CH (Dash Cam) (already on fuse tap installed on fuse #23)
- ESCORT MAX 360c (Radar Detector) (T-Tap into fuse tap #23)
- Quick Charge 3.0 Dual USB Truck Charger Socket (T-Tap into fuse tap #23). This will power an AT&T Netgear Nighthawk LTE Mobile Hotspot Router through the USB port.
Device Information:
#3: USB Hub:
