Ohm question
Ne1
MacDaddy lookin for the $
225
Tampa, Fl
Ok, I'm planning on running 3 subs off of a older RF DSM 100 and I was thinking that to stay at 2 ohms mono I would need to go 8ohm/8ohm/4ohm. (8 and 8 are four, bridged mono, and then 4 and 4 then equal 2 right?) Would this make for any noticable disparity in sound or loudness? Or would it hopefully all run at 2 ohms and play nice with each other? All subs will be of the same brand/model except for the impedance...
yes, that is the correct ohm configuration. and no you wont get any disparity from any of the woofers. it doesent change their ohm load, they are set at a certain resistance and will always stay that way. when you wire them though, it changes what your amp is seeing.
Minus the fact that the 4 ohm sub will be getting twice the power that the 8 ohm subs recieve...
Just get 3 4 ohm subs and run them in parallel. This will give 1.33 ohms and with impedance rise will net you around 2 ohms.
because i can?
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
It also lowers the amps efficiency and raises the current draw.
5
984
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
755
Ne1
Ne1
Tampa, Fl
hoss
Bobbytwonames
    Jul 20, 2024
