ohm load???
if you have three duel two ohm subs, there are a lot of different possibilities, but i'll just give you the ones that will work with most amps.
by running a normal parallel, you could actually get it down as low as .25 ohms, but i only know of a few amps that will handle that, and even then they have to be cooled.
a series-parallel is really versitile. you can either get 2 ohm, 4 ohm, or 1 ohm, but explaining how to do it in writing would be like explaining the color purple to a blind man....at least for me.
here's the best i can do:
http://www.termpro.com/articles/spkrz.html
that has everything you need to know for basic series, parallel and series-parallel wiring.
Wired series-parallel you'll get a 1.33 ohm load.
Wired parallel-parallel you'll get a .33 ohm load.
Info was taken from JL Audio's website on the W3 speaker page. Go to http://www.jlaudio.com/subwoofers/12w3.html then click "normal" under custom box design. It gives all kinds of ohm loads for multiple speaker dual voice coil operations.
Option 1 is the VC's wired in Parallel
Option 2 is all the VC's wired in series
Oldest thread brought back to life, only because its my B day //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
fu-man-chu
fu-man-chu
ngsm13
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
