new speakers in 1999 denali
coolman91985
Dallas
what are the biggest speakers i can fit in my denali? mounting depth, size, and what size are the rear roof speakers and there mounting depth? i really need to know cause i am gettin different answers from some of my friends... thanks
Here is what I have in mine.....I have the new alpine 6 1/2, in the front and 6 1/2 in the kickpanel. In the rear side doors went with Pioneer 6 1/2. In the front you will have to watch out with the woofers magnet hitting the window. Also have two 15 w3's in the rear. With directed 1100d and the directed 500 four channel to run the mids and highs. You can go with any 6 1/2 in the front. Just make sure when you try to fit the woofer in that it does not break the window...just roll it up and put the woofer in then just lower it real slow, just incase.
i need to know the mounting depth before i buy my speakers. that is y i am asking, cause right now, in my sentra, the basket hits the window and they wont roll down all the way. anyone know the mounting depths????
My guess is the dash speakers are more sensitive plus they're getting a boost from being closer. Maybe a cheap L-Pad to dial the dash speakers down.
77
All things being equal in comparing speakers on the same amplification, the difference in overall volume will be slightly less with a same...
9
348
I installed 2 12s and an amp in my 1998 ford ranger, everything is soldered and hooked up, tested power and ground they are good and the amp turns...
coolman91985
coolman91985
Dallas
coolman91985
Bobbytwonames
    Jul 20, 2024
