New amp and subs just in
Scorpion
HOLY CRAPOLA, just got my amp and subs in from Ebay.
Lanzar Vibe 248 and 2 2003 Kicker Comp VR 10". I am so excited I could just blow my up something.
Ok, now that is over. Some quick questions.
I know how to wire a SVC sub to an amp without any problems. These Kickers are DVC and a little confusing. Series or parrallel wiring?? What is the difference? The destructions for the subs only show a one channel amp for each sub (confusion sets in). The Lanzar is 2 channel, one sub for each channel.
How do I wire the subs to get the best results from them??
A friend told me to wire the subs TOGETHER!! And then hook them to the amp. Is this correct or is he blow smoke??
Thanks for the input. **** this is cool, finally some tunes in the pickup!!!!!!!!!!!!!!!!1
well here r the specs on the amp...2 x 300 Watts RMS at 4 Ohms
2 x 600 Watts Max at 4 Ohms
1 x 1200 Watts Max at 4 Ohms Bridged
2 x 500 Watts at 2 Ohms
now all u have to figure out is weather or not u have the dual 4 ohm subs or dual 2 ohm subs....
if subs r 2 ohm: u have to run them at 2x 500
if they r 4 ohm: u can run them at full power at 1x 1200 bridged....gl
The subs are 2 ohm, 300 watts RMS. The amp is 2 ohm stable.
They will sit in a fiberglassed enclosure that will have approx. 1.25 cubic feet.
See if this should be the way I wire these up or something different. Friend told me last nite this is the way he wired his.
Kicker 2.doc
  • Kicker 2.doc
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Scorpion
Scorpion
Goodland, KS
Scorpion
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
