Needing help
Alright I'm tired of trying to figure this out and understand this on my own. It's been eating me up all day. I'm wanting to get two psi platform 3 15s. Ok. They have a dual 1 ohm (0.7 DC) dual 1 ohm (1.0dc) dual 2 ohm (1.4 DC) and a dual 2 ohm (2.0 DC) ok are you following me. I'm wanting to get a taramps 8k. Alright. They offer a 2 ohm and a 1 ohm. Now the 1 ohm is far better. If I wanted to get the 1 ohm, What speaker selection should I make, and how should I wire them, And is it possible. Sounds simple, I feel dumb.
F0BVwbCyvur7C3XF2
d2 wire to 1 or 4 ohm, so u be at .5 ohm if u wire to 1 ohm each.. 1.4 ohm wire to .7 or 2.8ohm so 2 would be .35 or 1.4ohm (not bad but depends what amp does there and power u want).. d1 is .5ohm or 2 ohm each so u could get 1 ohm outta that.. see what popwar says he had that amp i think maybe those subs better to be at 1.4ohm on that amp depends on power u want or how hard u want to drive the amp..
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
You got plenty of space 30"h x 40.5"w x 65"d even triple baffled, double walled with bracing. What vehicle is this going in may I ask?
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
715
So I have a 12" 2500RMS 1ohm stable Skar Audio subwoofer paired with the corresponding Skar amplifier that pushes 2500RMS at 1 ohm. This is in a...
152
Techydrone
Tennessee
Techydrone
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
