Need to replace front comp Amp: Need SMALL Amp Recommendations.
Pete
I am looking for an amp to run my front components, but I want to keep it under the passenger seat of my car where the current amp is.
The amp I have now is 8 x 9.75 x 2.1" and BAAAARELY fits. the amp can be a little longer but no taller or deeper.
Oh, and I want somewhere between 90 and 130 actual watts by 2 channels. (90-130x2)
Right now money is not much of a concern,, but would like some inexpensive suggestions as well as a price range that could get me into the JL - Orion - Xtant category.
Thanks,
Pete
The 1.1i is a full range mono block though. So you would have to have two or run both sides from the one channel and lose stereo capability in the front.
I think the Planet Audio BB100.2 might be the amp I'm looking for, unless anyone has something bad to say about it.
Where can I get a good deal on the planet audio amp?
Oh, and I think the Xtant mono block 1.1 are cool as hell too.... I've had way to many killer install ideas using 6 or 8 of those little amps mounted and molded all over the car.
Thanks guys
Pete
Look into some of the Eclipse amps. Mine is a four channel is about the size you need so a two channel Eclipse should be the size you need. They sound excellent too.
I’m leaning towards the xv3 tbh. I’m also leaning towards adding the rings or if I can figure out how much taller to raise the top portion of the...
16
499
Two of these in that box would work great. https://www.ctsounds.com/collections/tropoxl-subwoofers/products/tropo-xl-12
12
469
Just remembered, I have that same coaxial/comp set, BNIB, $245 shipped if you are interested. I have the matching coaxials, took these of the...
12
611
I had this same amp installed about 9 months ago with no issues whatsoever which make all this odd
10
Pete
Pete
Minneapolis, MN
Diplexers
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
