need help wireing subs
partykman
4
va
hey i just got two infinity reference's 1232w.
300 rms
2 or 8 ohms
and i have a RF 451s amp i was woundering what the best way to wire these subs to get them to play there best.
please some one help!!!
//content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif thanx
k i think both subs are dual 4ohms correct? if so wire each sub in paralell to get a 2ohm load then wire each sub to its own channel on the amp
parallel is when u connect both positives together and both negatives together
hope that helps
thanx alot for all the help i just have one more question.
my amp puts out
115 watts RMS x 2 at 4 ohms
225 watts RMS x 2 at 2 ohms
450 watts RMS x 1 bridged output at 4 ohms
and my subs can only handel 300rms 1200w peak will this blow my subs or amp if i run it bridged
i was told to set it up two dif ways which way should i do it. im nervus lol dont want to blow anything or fry anything. but i want it to hit hard and i was going to build (2) 2 cudeft ported boxs do you think they will hit hard thanx again for all the help.
partykman
partykman
va
partykman
1aespinoza
    Jun 23, 2025
Mitchell Fosgate III
    Jun 22, 2025
