Need Help Deciding Which Amps to use
jokertlr
I am putting a half new system in my Chevy Colorado Crew Cab and I'm using some left over equipment from my last install and I'm not sure which amps I should use for what. The only thing I am sure about is that I should use one of the MRV-1005's for the sub. I'll list the amps and their specs plus the speakers and their specs. Let me know what you guys think I should use for what. I know there has to be a good mixture in there somewhere. Any suggestions on how I should bridge and wire them to the speakers would also be greatly appreciated. I also have a question about preamp voltage. These amps are set up for 4V from the HU, what if anything negative will happen if a higher voltage is sent from the HU?
Speakers...
CDT
CL-61's for the front doors (I'm also adding an image enhancement kit)
Mid: Stamped 6.5"
Crossover: "Phase Perfect" Elliptic 4th order 2-Way SatNat-456
Tweeter: TW-20 silk soft dome or titanium dome
Power Handling: 90 watt RMS
Frequency Response: 60-20kHz
Sensitivity: 92.0 dB
Impedance: 4Ohm
CDT 6.5 Mids for rear fill
Diamond Audio (sub)
M610D4
Specifications
Power Range (W RMS): 800
Impedance (ohms): Dual 4
Sensitivity (dB SPL): 90 (2.83-V input @ 1 meter)
Freq. Resp: 22Hz-250Hz(±3dB
Amps...
MRV-1005 V12 Expert (I have 2 of these)
RMS Power (at 12V, 20Hz—20kHz)
Per channel into 4 ohms ........................................................... 100W x 2 (0.08% THD)
Per channel into 2 ohms ............................................................. 200W x 2 (0.3% THD)
Bridged 4 ohms ....................................................................... 400W x 1 (0.3% THD)
RMS power (at 14.4V, 20Hz—20kHz)
Per channel into 4 ohms ........................................................... 150W x 2 (0.08% THD)
Per channel into 2 ohms ............................................................. 300W x 2 (0.3% THD)
Bridged 4 ohms ....................................................................... 600W x 1 (0.3% THD)
General
Frequency Response ................................................................ 10Hz—50kHz(+0,-1dB)
Signal to Noise (S/N) ............................................ 110 dBA (referenced to rated power)
Input Sensitivity (for rated power) ............................................................... 200mV to 4V
Slew Factor ......................................................................................... greater than 5
Input Impedance ......................................................................................... 10k ohms
Speaker Impedance ............................................. 4 or 2 ohms (stereo), 4 ohms (bridged)
Dividing Network .................................................. 50Hz—200Hz HP/LP(12dB/octave)
Equalizer Center Frequencies ................................................................ 50Hz—200Hz
Q Factor (bandwidth) .................................................................................... 10 — 1
Boost and Cut range .......................................................................................12dB
Power Requirements ...................................................... 11—16V DC (negative ground)
MRV-F405 V12 Expert (one of these)
Per channel into 4 ohms ............................................................. 40W x 4 (0.08% THD)
Per channel into 2 ohms ............................................................... 50W x 4 (0.3% THD)
Bridged 4 ohms ....................................................................... 100W x 2 (0.3% THD)
RMS Power (at 14.4V, 20Hz—20kHz)
Per channel into 4 ohms ............................................................. 60W x 4 (0.08% THD)
Per channel into 2 ohms ............................................................... 80W x 4 (0.3% THD)
Bridged 4 ohms ....................................................................... 160W x 2 (0.3% THD)
General
Signal to Noise (S/N) ............................................ 105 dBA (referenced to rated power)
Speaker Impedance .............................................. 4 or 2 ohms(stereo), 4 ohms (bridged)
Dividing Network ................................. 50Hz—8000Hz HP/LP/Bandpass(12dB/octave)
MRP-F356 Flex 5 (one of these)
MAX POWER (EIAJ)
•75W x 4 + 180W (4 Ohm Stereo)
•180W x 2 + 180W (Bridged 4 Ohm)
RMS Continuous Power (Watt) (at 14.4V, 20-20 kHz/ *:20-200Hz 0.3%THD): 4 Ohm Stereo (0.08% THD) 30W x 4 + 100W*; 2 Ohm Stereo (0.3% THD) 40W x 4; Bridged 4 Ohm (0.3% THD) 80W x 2 + 100W*
•S/N Ratio 100 dBA
•Frequency Response (+0, -1dB) 10-50kHz
•5/4/3 Channel Operation
Bump yet again... I can't believe no one has anything to say about this. I have all the information on the products I need advice on and no prior knowledge is needed. Most threads on here start out with "I need 900 watts on some speakers" and they get 800 replies.
jokertlr
jokertlr
Wisconsin
jokertlr
RobGMN
    Apr 28, 2025
ThxOne
    Apr 28, 2025
