My System
yea if you want to spend 400 dollars on a sub that hits hard enough to change your DNA and clean enough to wash your car then get the DVC 4ohm 15xxx. youll probably need component upgrades and component amps if you want to hear anything besides bass
Your budget is?
Ditch those kenwoods and get some other subs!
1 15"XXX 4ohm DVC from RE comes to mind!
RF 1500.1bd does 1700watts @2ohms mono! PERFECT MATCH!
Gotta pay extra for the DVC 4 ohm though. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
For some extra peace of mind, you could do a big-3 upgrade with the same 4 guage ofc wire.
278
Disconnect the amp for a day or two, then connect it back up. If it stops draining when unplugged then drains again, take it back and have them...
I would also recommend checking all the amps wiring to make sure secured/ tight and ground is solid and remote making solid contact in the terminal
7
709
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
621
ManZ
ManZ
Modesto,CA
tommyk90
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
