My fault? RE HC's?
brothaknowles
OK I am really needing some help with my setup I guess, i dunno because I have 2 RE HC 12's, a gnomeaudio box, and a memphis 1500watt amp i also got from gnomeaudio. Well It's all installed etc.. but if I try and crank it up at all the hits just end up distorting everything. It's really dissapointing because its almost as if they just can't handle it.. I bought them because they were acclaimed to have amazing sq, and a really hard hit etc.. I'm sure I didn't do somethign, or did something wrong but can anyone help?
When it gets really low, or really hard, they just kinda sound they they are bumping against the back or something (the box is huge and doesn't seem possible), and they kinda pop and i dunno.. My gain is only about 1/3 up, the bass boost isn't on at all, and the phasing and crossover don't seem to effect the problem so i dunno... pleasee help me!?
set your low pass to 80 hz (you can change it to your ears once you listen for awhile), keep the gain under +3db. if youve already done all that then maybe they really cant handle it, or the amp is a POS. dont know what else to tell you.
brothaknowles
brothaknowles
Wichita, KS
worm
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
