OK so some of you car geniuses please give me some ideas. I'm completely burnt out on this.
So basically the car isn't working correctly and no one seems to know why.
K the type of car is 1986 S-10 Blazer. It is 4WD and has a 2.8L V6.
Briefly, the symptoms and problems it has are as follows:
1. At times the car won't accelerate when you give it steady gas, if you feather or "pump" the accelerator, it will progressively rev up, but never really wants to go more than about 45MPH. Steady pressure on the accelerator causes the RPM level to drop to the point of stalling out.
2. While engine is revving, stays running fine, when you come to a stop light or stop revving it, it will idle fine for a little while (about 20-30 seconds), then RPMs rise by about 200, then drop back down and the car dies.
3. The above conditions exist with the MAP sensor Vacuum supply disconnected. When it is connected, the car will not idle enough to remain running. It turns over fine, but won't stay running for any period of time (unless the car is VERY warmed up "has been running for at least 30 min") then with the sensor connected, the car idles more steadily and doesn't die.
4. As a side note, there is an exhaust leak at the donut which connects the manifold to the pipe, but this leak has plagued this truck forever.
5. Diagnostic codes popping up are 33 and 34 which are low and high vacuum pressure to the map sensor. and 44 and 45, which are rich and lean exhaust detected.
6. visually, and from the smell, the injectors are dumping far too much fuel.
I've had TONS of people give me second opinions and advice and i've done alot of work which has gotten me nowhere.
Attempted repairs are as follows:
Replaced Map sensor, O2 sensor, several leaky vacuum hoses, Sparkplugs and wires.
Checked vacuum levels (ok), EGR valve function (ok), dealership ran computer tests (ok), timing seems ok.
after 300$ in diagnostics, the dealer tells me that the exhaust leak is causing the O2 sensor to detect lean and dump more fuel, flooding and causing misfires. I personally think that sounds like crap.
My next plan of attack is to try replacing the fuel pressure regulator diaphragm.
Any thoughts geniuses?
Or know of the best forum to post this question to?
