memphis mojo amp, need help
bumpinrecords
I have a memphis mojo amp and 2 mtx 9510 subs. when i bridge the amp it sound the same as if i ran it 2 channel. Shouldnt the power like increase drasticlly when i bridge it and what could be wronge . When i bridge it i use the 2 outside speaker terminals the - all the wasy to the left and the + all the way to the right help me out please
Ok the Mojo is a mono block amp. It has 2 +'s and 2 -'s so you can hook up 2 speakers easily but it is still mono.
If you hook up 2 speakers to it, that are 4 ohm loads, you will get 2 ohms mono, and if you then wired the 2 speakers to get a 2 ohm load, then only hooked up 1 set of +/- you will still have a 2 ohm load and get the same power.
Hope that helps,
Craig G
man thanks alot the subs i am using are 2 mtx 9510 they are 4 ohms each so i would use one set of + and - and do it matter what ones i use or use the outer + and outer - thanks alot. I jsut need to figure whta box to use in my 2000 firebird. Also with this set up what do you think i will be doing as far as pressure keeping quality in mind
bumpinrecords
bumpinrecords
chicago
bumpinrecords
Jared Schwersky
    Jul 19, 2026
Jared Schwersky
    Jul 19, 2026
