LoudCrownVic
1/1 of Team Team Team
I went into my friendly neighborhood pawnshop and found, much to my surprise, a Kicker Solo baric 15," in about a 4cu ft ported box i assume it is to the factory specs of the woofer. When you so much as tapped the cone an satisfying thud came out of it. The proprietor hooked it up to California 600 and it bumped fierce. I think it might be a an equal (i.e. replacement) for my 2 15" Orions, which in all honesty need more power than I can afford to be any louder than I already have them (140 maybe as much as 145 estimated db by audio pro) The Kicker is a dual 4ohm voice coil with I think handles 1000 watts max power. This is perfect as my amp is 2 ohm when it is bridged, and it's max power is 1000 watts.
So.................
Will the Kicker outdo the 2 Orions (1000 max 500 rms 4 ohm svc) which were probably produced in the early 90's, or should I dump them and put in the single Kicker? BTW, I do really like my Orions, but if the Kicker can outdo them I can get 300 offa them and come up and out 100 bucks up so i can buy that pair of Alpine 6x9's I've wanted for 6 months now.... Enlighten me.
So.................
