mail me back
asif_won
hi
i just got memeber of this site.i have a question for u . i have got TS-W1201 pioneer subwoofer . i dont know which amp to buy for it.can u helpm with it . the woofer is 1000 watts.please mail me soon i am desparate to get me system on road .pleas e tell me 5or 6 amps.
ok well let see before I can be of much help I wil need more information about the sub,,,,,how many do you have? Is it 1000w peak or RMS? What kind of encloser is it in? What size is the sub? Once you give this information helping you will be much easyer......
Adam
hi
thanks for replying.well u asked for whats the size of the sub and its power. well TS-w1201 is 12inches in size And its rms is 500 watts and peak power is 1000 watts And i have made a enclosed box for it and i am putting it in my boot.tell me also where to put it.if the boot is not alright for it.i also asked u about amps.please tell me the names of 5 0r 6 amps about my woofer ,because we have not very much variety of amps here.if u tell me on amp for my sub that i might not find here.hey i am buying crunch 250 watt amp for my four 300 watt peak phase linear speakers,should i buy the amp for them.i have got just one pioneer sub.
waiting for u r mail.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Ok well I have a list for your pioneer sub:
********#1----Rockford Fosgate model BD1000.1*********
* Class bd technology
* 1000 watts x 1 at 2 ohms
* 500 watts x 1 at 4 ohms-( I think)
* selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
* MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
* TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
* NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance.
* preamp outputs for easy connection to a second amplifier
* wired remote control of Punch Bass (0-18 dB centered at 45 Hz) — gives you fingertip control of your bass impact
* subsonic filter removes frequencies below the range of human hearing for increased efficiency
* 100-amp fuse and fuse holder required
* dimensions: 14-7/16"W (10-7/8" without endcaps) x 2-7/16"H x 9-7/8"D
**********# 2---- Sony XM-3001SXDl*********
1000W Max Power (1000W x1 @2OHM )
* 500w rms power (500w x1 @4OHM)-( I think)
* D-class Amp
* Digital Bass and Treble
* 21-band Digital Equalizer
* 300W x1 into 4O , 5-200kHz, at 0.04% THD
********# 3---MTX THUNDER1000D*********
RMS POWER (12.5 Volts DC):
500 Watts x 1 into a 4 Ohm load with less than 0.5% Thd+N
1000 Watts x 1 into a 2 Ohm load with less than 1% Thd+N
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC
850 Watts x 1 into a 4 Ohm load
1500 Watts x 1 into a 2 Ohm load
Signal to Noise Ratio:
100dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-200Hz
Maximum Input:
8Vrms
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
EBC External Bass Control
Crossover:
Variable 40Hz to 200Hz, 24dB/octave low pass
Dimensions:14" x 9" x 2" (35.6cm x 22.8cm x 5cm)
15-1/4" x 9" x 2" 38.7cm x 22.8cm x 5 cm) Including IsoFeet
*******#4---Audiobahn A1500HCX********
Amplifier Specifications
Amplifier Type: Mono
RMS Power: 500W x 1
Bridged RMS Power: 1000W x 1
THD at Rated RMS Power: 0.02%
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 10-40,000 Hz
Channel Separation: 84 dB
Signal to Noise Ratio: > 100 dB
Fuse Rating: n/a
Well I know that is alot to read but I looked online and I think that any one of the amps I listed would do the job for you very well...These are all high-end amps that may be expensive but are also hig quality....I don't like recommending crap to people...Hope this info helps you..
Adam
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
hi
well that what i was expecting. i couldnt find any of the amps u mentioned.we have got here jbl amps, jensen amps. boscht amps,can u tell me any one of those to buy.hey should i buy crucnh 250 watts for my four 300 watts phase linear speakers.
jbl is a good brand
hi
hope u to be fine, thanks foer the reply. i didnt tld u the exact description of my sub.well i didnt know what it was . sorry . now i have sub in front of me.it is TS- W1201DVC. i hope u know what does dvc means. it has two input buttons.its peak power is 1000watt. and its rms is 500 watt. first u have to tell me what amp i should use for it. a two channel amp or a four channel amp.it has two inputs so i dont know what amp to use.plz mail be soon . iam dying to get it on road. keep in mind that it is a dvc woofer . the brand is pioneer. some body tld me to use four channel amp for it .is he saying right.tell me five or six amps.
bye
asif_won you said that you have JBL amps here. where ever it is that you go ask them if they can get you a 1200.1 amp. That would be way more than enough for the one sub and plenty to run 2 or 3 of them in the future if you wanted to upgrade. If the store wants alot for the amp it can be found on the net and not ebay, for under 250.
asif_won
asif_won
pakistan
blackgeltabs
Jared Schwersky
    Jul 19, 2026
Jared Schwersky
    Jul 19, 2026
