Line out vs aux vs 3.5mm audio vs pre-out
  • 1
Davefromlondon
I thought I knew my audio but apparently not. I am posting on another thread about connecting an old school cassette deck to a new screen aux in , this is a related but different, more detailed question.
I'm very familiar with home audio say a cd player with line out into receiver line in, receiver is both pre amp with volume control and power amp to speakers. Cd has no volume control , line out is fixed.
I'm familiar with iPhone audio out to ear buds with volume control , I also believe you can use iPhone audio out into an aux in of a pre amp so is audio out and aux in essentially the same. ?
I see an old Sony walkman offering both headphone audio out Jack 3.5mm AND a line out jack also 3.5mm. I assume this line out makes the walkman like the above cd player ie line out into receiver line in but using a 3.5mm audio jack into L and R CA .
I see an old school cassette sony xk8d that has no amp , just cassette play into a seoerate car cd radio head unit using aux in. I'm unclear exactly what output jack the xk8d uses. Is it 2xrca line out or 3.5mm audio .
Did old school car cassette decks , that had built in amplifier, did they also have " rca pre out " and if so , was the cassette deck also the volume control / pre amp , therefore a pure power amp is needed .
Then there are line out converters LOC , to take speaker level out and reduce to line level. I assume these become essentially pre out, ie the speaker out volume has volume control. What is the skund quality of doing g this
I realize line out is a fixed signal on a device that is not volume control and pre out is volume controlled by same device ie pre amp.
I guess I'm just confused on term aux out / aux in ......., is it essetially the same as headphone audio out , line out/in , pre-out/ pre-in ?
I researched but still confused and it is much appreciated.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
The preamp input on most amps is 10-20k ohms, so you don't really lose voltage. I've run plenty of systems off 2v preamps with no problems.
911
Davefromlondon
Davefromlondon
Dallas, TX
Davefromlondon
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
