kicker solobaric
gus--put your solobaric 12
in a sealed box
mesurments for box
height-- 14''
with-- 14''
depth-- 14''
for a total of 1.13 cubic feet
use an amp that matches the
rms power of the solobaric 12
allot of the class d amps are
capable of doing it . check them out
The only problem I see with the enclosure reccomended above is that you won't be getting nearly the SPL that sub is capable of producing. You say you have an extended cab, if you really don't need that extra space in the back, I would try to get an enclosure that was at least 2 ft/\3. And if you really want some boom, then you might want to check into a ported enclosure, and if that's the case then you would want to go with a little more space.
If you want SPL , PORT THAT BAD BOY!! If you want it to rattle your review mirror off, go for the port!
hey guys-- dont just say go ported
how about backing it up with some spec
for building a ported box (like)
height-of box
length -of box
depth-of box
and length-of port or ports
is easy to say go ported but building a
ported box a beginner in car audio will have a difficult time
in tunning his or hers box to a set freq where the speaker
will sound it best
building a sealed box a beginner wil have
a little more leway and it wood be easer
for a beginner to build ( just a thought)
My box is:
H-12 inches
L-32 inches
D-18 inches
Take in mind this is for 2 10" L7, and its made for a mustang not a pick-up, Hey GUS if you would be kind to give me Dimentions of your cab I'll be happy to help you with-a ported box, (if thats even what you want)and come up with the dimentions for a box.
good luck, got a question post it.......
Gus
Gus
houston
fu-man-chu
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
