Kicker KX400.1 vs Fosgate 501s
Well, the 501s is a 2-channel amp and can't be run to a 2 ohm mono load that would be created by wiring up 2 4 ohm subs (unless they are DVC 4 ohm) and the 400.1 is a mono amp that can be run @ 2 ohms, I would have to say the 400.1. If you want a Rockford amp look at the 501m mono amp.
Post sales in the classifieds, with a piece of paper that has your username and date on one of the pictures of the equipment that you post...
127
Make sure when you get that headunit you turn off the useless blot features. I pretty much exclusively use Kenwood's cause of the user interface...
31
777
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
jeffd398
jeffd398
West Palm Beach, FL
jeffd398
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
