Kenwood 6x8 vs JBL 6.5"??
  • 2
RBass22
Hi all, I'm new to the forum and haven't done much with car audio since 2008'ish. I'm planning a very simple system for an old '98 F-150 extended cab. Going to be running an aftermarket HU, 2 sets of 6x8's (Kenwood KFC-C681 - 81w RMS - 4 ohms) or 6.5's (JBL GX628 - 60w RMS - 2 ohms) in front & rear doors, and 2 JBL 12's in ported enclosure. Will be running mids/highs off an amp with 60-100w rms per channel. My question - is it worth it in this case to build/buy adapter plates to run the 6.5's or would you just go with the 6x8's? They both sound decent (for the price).
Hey mate,
With a similar size speaker, not much difference as the cone areas are identical. Only difference is that one would have a more efficient tweeter to the other. Secondly, if you sound deaden the doors then that will provide you with a better detailed midbass, not low bass. Using your kenwood amplifier, sound deaden them doors and give what you have a go, before you go out and spend more cash on new speakers which is not worth the improvement unless you want to add a dedicated subwoofer and another amplifier. With car audio, you may be fiddling around changing speakers, subwoofers until you are satisfied for a while then its of again! That is what I do mate, but you maybe more content then me! :)
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
460
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
RBass22
RBass22
Orlando, FL
DRBOOM
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
