jl w7 13 vs. mtx 9515
on what amp??? In which type of box??? There are several different factors in deciding what is "better" in SQ and SPL. You just can't ask is sub A better than sub B. Need more info to make a better conclusion...
Jon
i would go with jl but i havent heard the mtx personally but from experience the mtx wont stand a chance with jl
You haven't head the MTX, but it won't stand a chance against the JL? Somehow the square block isn't going in the circle hole here ...
Listen to both subs. Decide for yourself. It's a tough choice if you don't do that..
- Steve
which sub would have a better spl and sq?
Dernit, I knew this was coming.
The recent talk about the MTX 9500 series, and the JL w7....
Equals?
Dun Dun-Dun!!!....
The Dreaded, and oh so played out "versus thread". LOL, just kidding, sort of.
Better SPL? In what? A sealed box?
A vented box? Tuned to what?
With what power?
Better SQ? I don't care what anyone tells you, an MTX RFL could sound better to YOU than a W7. That's all on YOU.
I literally think me beating on a table sounds better than ANY L7 I've heard.
What if I told you to go buy a table and put it in your trunk? Hey, no amp necessary! And it'll sound better than an L7! Would you do it?
We MIGHT be able to set you str8 with an anwer SPL wise, but not likely with "SQ".
BTW, don't take it the wrong way. I'm just being sarcastic, sort of....lol
LOL....wow that was funny
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
971
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
3K
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
jus_n
jus_n
Kauai,HI
limitkid7
spokey9
    Jul 17, 2024
1aespinoza
    Jul 15, 2024
