jeep system
I'm putting front speakers in the dash of my 2004 jeep wrangler. Does anyone know which colors are positive and negative for the wires? Is there any way to tell? Where would be a good place to mount an amp?
Goin off of what is in my 00Wrangler, the wire w/ the white stripe on it is the negative charge, and the other the positive. My amp is mounted under the back seat w/ a cooling fan, it fits nicely and you can reach the controls pretty easily. Ive also seen amps mounted under the driver seat, and that seems to work farily well too. Just be sure to screw it onto a piece of plywood if you're mounting it right to the frame //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Really never a great idea to mix tweeters and caxials in the front, screws up the sound and the staging. I would replace the set with a 6x9 woofer...
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
957
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
6
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
9K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
buster
buster
Dallas, TX
omnipseudo
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
