Jbl Bp600.1
well most batterys put out 12V while the engine is not running. When the engine is running it puts out the 14V. I don't really think it matters b/c if it is rated at 12V you are going to get more power at 14V and if its rated at 14V then that is what you get. You should never use your system when the engine is off so assuming your electrical system can handle it you should be runing at 14V
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
  • Locked
COMPLETED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
7K
joerodd
joerodd
NW Ohio
kickerlivinloud
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
