Jbl 600.1 and 12 RE SE
Nixxed
I had a problem with my sub and had to disconnect it and send it back to RE. i am getting it back monday, but i noticed the way the shop installed my amp and sub was 4 wires from the amp, 2 neg'ss and 2 pos's to teh sub, for each voice coil there was a neg and pos wire from the sub. Is this the proper way it should be wired? or should i just run 1 neg and 1 pos to the amp, like in the picture that is sticked at the top?
sounds right to me dual 4ohm sub wired paralleled to 2ohm.
i think 2ohm is where that amp puts out the 600wrms.
like this.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
  • Locked
COMPLETED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
7K
Nixxed
Nixxed
Los angelees, CA
tat2
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
