My gain is on it's highest setting on the amp and I'm at +9 out of 15 on my HU. I have an L5 10". Is this ok for a 10 "?
Nah bruh, It wouldn't even be ok for an 18".
Why would you turn your gain up ALL THE WAY, AND boost the bass?
I bet your system gets loud really early in the volume dial, then it doesn't get any louder about mid-way, and it just sounds distorted after that.
Your volume knob is on your HU, NOT your amp.
If the gains were meant to be all the way up, no amp would have a gain to be adjusted externally. They would all be at max settings internally.
And again, you don't need to boost any bass frequency that your amp is producing when it's already at max output.
How can you boost what you don't have?
You can't give 10 more dollars when you've spent all the money in your wallet.
How can a 500 watt amp put out 500 watts and then someone try to boost bass, and expect it to somehow put out more and/or get louder?
Both of you need to turn your bass to zero on your HU, turn your gain all the way down, turn your volume on the HU were you are comfortable with the sound from the in-car speakers, then turn your gain up until you start to hear distortion, then turn it back just a hair.
I say to listen for distortion, but it doesn't seem like you know how to detect distortion, bcuz your amps have to be clipping the way you describe your settings.
