Installing Subs on Car With Factory Amp
  • 1
zamen40
CarAudio.com Newbie
I have a Toyota Yaris 2019 which comes with a factory amp. I'm trying to install subwoofers with the stock radio, and have very basic knowledge of the process. I found people use a line out converter to convert the higher voltage speaker wire signal to a lower voltage pre-amp signal. If there is an input into the amplifier for the rear speakers would I still need to use a line output converter? I found this youtube video of someone doing a similar job on a 2018 Yaris iA https://www.youtube.com/watch?v=GAlRuf2Q2Rk. In this video, he seems to connect his RCA cable directly into the amplifier input using an RCA splitter cable.
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
zamen40
CarAudio.com Newbie
zamen40
zamen40
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
