installing a alpine cda-9833
mikesta
8
Hawaii
hi, a few quick questions from a first time installer:
1. I'm at the point where i'm trying to connect the amp wiring to the headunit. i have some 10 gauge and it is mad thick compared to the power wire on the HU. is the only way to connect them by sodering or is there another way.
2. the illumination wiring on the HU and the harness are formatted differently. the wiring on the HU has a plastic cone around it, as well as a metal tip. do i cut this off in order to connect the HU's illumination wire to the harness' illum. wire?
thanks for your help
you unscrew that plasic cone thats the only answer i know... my bad //content.invisioncic.com/y282845/emoticons/wacky.gif.cf4a48f9e6dfe9504ffd2c946fd2f340.gif
thanks for the reply, i'm sure i posted this in the wrong forum seeing as there's an installation help forum, but thanks again. anyone know the answer how to direct-fused connect the harness to the 10 gauge wire?
Hey Mike,
If I'm not mistaken Alpine says to fuse and connect the power wire to the battery.
Other than that get a butt connector and crimp it OR solder it and heat shrink it
to the factory radio power wire
Best of luck to you.
Peace
Mike on this point you have to find which wire is the factory radio illum wire and splice it to the Alpine illum wire. OR go to Radio Shack or a auto parts store and see if they sell a bullet connector that will recieve the Alpine part.
Peace
thanks fellas, you guys were an awesome help //content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
795
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
mikesta
mikesta
Hawaii
mikesta
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
