Installing 2 monoblock amps?
qwkracer
If my headunit only have 1 sub preamp output in the back, how can i install 2 Monoblock amps? (2 Hifonics BX1500D). installing one amp is easy because all i have to do is run the RCA cable and connect it to the head unit.
how about the RCA cable needed for the 2nd monoblock amp? the preamp is already used up, what do i do? do i need a special piece/item or somthing?
more questions,
I am using a 0 gauge stinger power wire. can this wire handle two monoblock amps with a total output of 3000 watts and a 4 channel amp rated at 350 watts? or should i use the 0 gauge for both the Hifonics BX1500D amp and use a seperate 4 gauge wire for my 4 channel amp?
Please help!
All you need is to use the preamp output of one of the amps to drive the other one. Run your sub out from your HU to one amp and then run another RCA from the output of that amp to the input of the other.
If you run the amps full tilt much (competition basically) I would run another power wire for the 4-channel. Otherwise you will be fine.
make sure you get a meter and check the out put on the amps and set the gains where they are sending out the same,because i know 2 amps are not made the same they always differ on power even if htey are the same amps.well thought this might help.
My guess is the dash speakers are more sensitive plus they're getting a boost from being closer. Maybe a cheap L-Pad to dial the dash speakers down.
97
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
831
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
qwkracer
qwkracer
Sacramento, CA
houston281
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
